intake manifold leaking in the front?
Old Dec 20, 2006 | 02:23 PM
chevygirl's Avatar
Default intake manifold leaking in the front?
Is it possible for an intake to leak on the front in one spot only 3 months after a new engine installed?
Old Dec 20, 2006 | 03:40 PM
ss64impala's Avatar
anything is possible. i assume you mean leaking coolant? do you have any type of warranty?
btw, i see youre from memphis,i grew up in tipton county.
Old Dec 20, 2006 | 03:49 PM
chevygirl's Avatar
I am in memphis. Yes I do have a warranty on it. I just thought it was weird it would wait 3 months before it leaked. It looks like it is completely sealed off on the front but there is a trail from the intake down. Good to hear from someone that use to live around here. You sure moved a long ways away.
Old Dec 20, 2006 | 04:32 PM
ss64impala's Avatar
your problem is most likely an incorrectly torqued manifold. believe it or not, very rarely is an intake manifold perfectly straight. this is why the two middle bolts must be torqued first,then work your way out, torque one side,then the other, until reaching the end.this will work out any reasonable warp in the manifold insuring a proper gasket seal. since it is under warranty- i would have them pull the manifold, install new gasket and retorque this way. id hate for them to torque it wrong and your problem return later down the road. hope this helps.
byrne_06
Apr 29, 2017 02:19 PM
OHsixLS3
Dec 27, 2016 09:30 AM
USMCvet0311
Sep 30, 2015 10:34 AM
Hmguyton
Jul 7, 2015 03:29 PM
Black-Syde
Jul 6, 2015 02:12 PM
