Intake manifold?
Old May 18, 2010 | 08:53 AM
david0982's Avatar
Default Intake manifold?
Are the 99 5.3 and th 05 6.0 intake manifolds the same besides the trottle body?
Old May 18, 2010 | 09:34 AM
DV2000NJ's Avatar
13 Second Truck Club
The 99 will probably have the fitting up by the throttle body for the EGR, and also have one extra vacuum fitting for the fuel pressure regulator. Also on the 99-02s the vent hose from the passenger side valve cover went to the throttle body, on the DBW intake manifolds, it goes to the manifold itself right behind the throttle body (if you're using your DBC throttle body, there will be some clearance issues there). The '05 manifold also won't have all of the threaded brass things for the throttle cable bracket. At least those were the differences I found.
You can make it work pretty easily, but if your old manifold is good, it'd just be easier to use that.
byrne_06
Apr 29, 2017 02:19 PM
OHsixLS3
Dec 27, 2016 09:30 AM
USMCvet0311
Sep 30, 2015 10:34 AM
Hmguyton
Jul 7, 2015 03:29 PM
Black-Syde
Jul 6, 2015 02:12 PM
