Intake manifold ??
Old Dec 23, 2005 | 03:54 PM
Onyx 02's Avatar
Default Intake manifold ??
I want to know if there are any differences in intakes, between one for a cable-driven throttle body and one for the drive-by-wire t.b. I'm trying to buy an '04 intake manifold from another member, which is for a drive-by-wire tb, and put it on my '00 Z-71, which is a cable-driven tb. I assume the intake will work, but want to know for sure.
Old Dec 23, 2005 | 09:55 PM
Onyx 02's Avatar
Anybody know???
Old Dec 24, 2005 | 03:49 PM
5.3 racer's Avatar
the drive by wires i've seen are usually missing some of the threaded inserts for the throttle cable bracket. depending on the year of your truck you also may have the issue of return and returnless fuel rails with the return style having provisions for the vacuum referenced fuel pressure regulator.
Old Dec 24, 2005 | 04:00 PM
99Silver6.0's Avatar
It will work. Im using an 03 intake on my motor that was drive by wire. Throttle brackets mounted up fine. Are you wanting to convert to DBW TB??
Old Dec 25, 2005 | 10:47 AM
Onyx 02's Avatar
I was thinking about it, but probably won't. My '02 has drive-by-wire, but my '00 Z-71 doesn't. I was just wanting to make sure that an '04 drive-by-wire intake manifold will fit my '00 and be able to use the cable-driven tb. I think I'll go ahead and get it from the guy and if it doesn't work, I'll use it on my '02 or sell it.
Old Dec 25, 2005 | 11:08 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Didnt know the 02s had dbw is yours special?
Old Dec 25, 2005 | 01:46 PM
Onyx 02's Avatar
Yep, mine has traction assist! I believe they started that option in '01. My '02 is a fully loaded LT, every option except for sportside bed, stickered for $34k.
byrne_06
Apr 29, 2017 02:19 PM
OHsixLS3
Dec 27, 2016 09:30 AM
USMCvet0311
Sep 30, 2015 10:34 AM
Hmguyton
Jul 7, 2015 03:29 PM
Black-Syde
Jul 6, 2015 02:12 PM
