installing whipple on 5.3. what to expect?
Old Feb 27, 2012 | 10:30 PM
kalebm22's Avatar
Restricted User
Default installing whipple on 5.3. what to expect?
my mods are in my sig. the whipple comes with a 10lb pulley and 52lb injectors. i will actually be using those injectors on my lt1 transs am that i am converting to e85 and using the 42 lb injectors on this truck. what kind of rear wheel hp should i be seeing, maybe quarter mile times?
Old Feb 27, 2012 | 10:35 PM
gasmachine85's Avatar
You my friend need to talk to aklowriderz71... but im sure he will chime in.
Old Feb 27, 2012 | 10:36 PM
Mangled03gmc's Avatar
Baltimore Whore
Should go in the 13's
Old Feb 27, 2012 | 10:42 PM
ak2007r6's Avatar
I say low 13's maybe 12's. The tires will hurt you a little but not sure how much.
Old Feb 27, 2012 | 10:46 PM
kalebm22's Avatar
Restricted User
ya, im sure they will kill me lol. i also have my stocke wheels and tires to throw on it if need be tho haha
Old Feb 27, 2012 | 11:12 PM
kalebm22's Avatar
Restricted User
what will this do to my mileage btw?
Old Feb 28, 2012 | 12:57 PM
kalebm22's Avatar
Restricted User
The injectors are actually 44lb Delphi injectors.
Old Feb 28, 2012 | 01:08 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Axle ratio & trans, stock cam?
I'd bet you'll get in the mid 13's on the big tires. Put the stockers on & get some low 13's.
You won't be able to get too aggressive with the tune, since you're not intercooled.
Old Feb 28, 2012 | 11:25 PM
kalebm22's Avatar
Restricted User
ok, is there a way to intercool these superchargers? i can fabricate like a champ. i just dont have the supercharger in my hands to see what can be done.it has stock cam with crane 1.85 quick lift rockers. i have 3.73 gears, and 4l60e with 3200 circle d converter. i will also be launching in 4x4 auto.
what do these superchargers do to fuel economy?
Old Feb 28, 2012 | 11:46 PM
Sincal T/A has done a bunch of work experimenting with intercooling the Whipple, and working with the inlet for a larger throttle body. PerformanceTrucks.net Forums - View Profile: SincalT/A Check out some of his threads and posts, or send him a PM.
As far as fuel economy goes, that all depends on how you drive it. If you stay out of boost, economy will stay the same. But when you go into boost, the PCM adds fuel....
Hope that helps!
