Installing the tranny cooler. Quick question
Old Oct 22, 2004 | 03:13 PM
WillPewter2000's Avatar
hmm by the way everyone was putting it I thought I needed to tap into the top line which I have already done. That sucks I may just leave it like that.
Old Oct 22, 2004 | 04:06 PM
MacADaYear's Avatar
Old Oct 22, 2004 | 04:51 PM
slowprocess's Avatar
Thanks BigTex. I'm going to install it tonight and hopefully the electric fans, if time permitting. I was thinking that maybe the temp would be raised back up if the cooler was first, then through the radiator, but I just wanted to be absolutely sure.
Old Oct 22, 2004 | 05:03 PM
budhayes3's Avatar
PT's Slowest Truck
The top isn't the return? Oops...wait, are you sure about that...cause I'm gonna redo mine if it's wrong...but I asked that question in a bunch of different places and performed a bunch of searches and came up with the top as the return. I'm positive that the top on the trans is the return, and I thought that I visually followed the top line from the rad straight to it, just to confirm my search results...but now I'm doubting myself.
Old Oct 22, 2004 | 06:03 PM
budhayes3's Avatar
PT's Slowest Truck
Just double checked my 99 Service Manual (If anyone wants to referece it, it's Volume 3, page 7-77), and the schematic shows the upper line as the return...guess I won't be swapping my cooler lines this weekend...whew.
Old Oct 22, 2004 | 06:16 PM
jlwz71's Avatar
Yep the top is the return on my 99.
Old Oct 22, 2004 | 06:19 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
My mistake. I guess I did mine the correct way then
Old Oct 22, 2004 | 07:18 PM
gonzo 6.2's Avatar
top is return
Old Oct 22, 2004 | 07:37 PM
So, is everybody sure the top is the return line?!?!?! I was just about to leave when I decided to check this post and now I see everything has changed again. So, now I tap into the top line right? You guys are killing me!
Old Oct 22, 2004 | 07:46 PM
gonzo 6.2's Avatar
easy test,pull the top line off,install the short fitting install two hoses,run them into a bucket and have someone start the motor for 3 seconds,fluid will gush out of the top,you'l see.fluid will blow out at 70PSI,only takes a second to avoid a mess and test.
