Installing LS9 head gaskets and ARP studs ?
Old Nov 21, 2011 | 02:19 PM
sharpshooter's Avatar
Default Installing LS9 head gaskets and ARP studs ?
After pushing coolant on my LQ4 I decided to install ARP studs and LS9 gaskets.
What's the best way to clean the heads and block?
Old Nov 21, 2011 | 04:46 PM
Steve-O-08's Avatar
Gasket scraper or a die grinder with a Scotch-Brite disc on it. Just be careful with both. Watched a friend but a nice divot in a nice 243 head trying to clean it up.
Old Nov 21, 2011 | 04:51 PM
TXsilverado's Avatar
i think it's 3m that makes some plastic disks to scrape gasket material. they work awesome and wont hurt the metal since it's just plastic.
Old Nov 21, 2011 | 06:04 PM
scooter k's Avatar
I would just use a scraper and a scotch brite pad.
Old Nov 21, 2011 | 06:06 PM
andrew383's Avatar
traveling mod
Ive used a razor blade and a scotch-brite pad from wally..
Old Nov 21, 2011 | 06:28 PM
Suburbazine's Avatar
I sharpened the edge of a paint scraper and used a Scotch-Brite pad dipped in engine degreaser.
Old Nov 22, 2011 | 10:33 AM
thanks!
Old Nov 22, 2011 | 10:38 AM
this is what i'm talking about. works 10x better than a razor and also 10x faster.
Old Nov 22, 2011 | 10:40 AM
took me less than 5 minutes to clean gaskets with plastic wheel, and another 5 to clean pistons with a steel brush.
Old Nov 25, 2011 | 12:56 AM
ShredSled's Avatar
those 3m yellow roloc wheels are pretty expensive.
I just used a scotchbrite type wheel on the block. I was more careful on the heads.
