Installing Longtubes
Old Nov 14, 2006 | 12:43 AM
spy2520's Avatar
12 Second Club
Default Installing Longtubes
I installed longtubes on my car, it was easy, i'm going to be installing some on my friend's 04 sierra, i figure it will be easier than an f-body install, am i in for any surprises? and what o2 sensors you guys run with longtubes the bosch 13111s?
Old Nov 14, 2006 | 01:05 AM
TXsilverado's Avatar
factory 02 sensors...install should be easier.
Old Nov 14, 2006 | 01:10 AM
jakebdb56's Avatar
should be an easier install, only thing to watch out for really is the steering shaft, other than that it's a piece of cake. I run stock O2's since they're not even a year old
Old Nov 14, 2006 | 04:31 AM
Mangled03gmc's Avatar
Baltimore Whore
It is defentaly easier to do the truck install, stock for the 02's..
Old Nov 14, 2006 | 04:57 AM
navy_ao_05's Avatar
its more time comsuming than hard plus if you know what your doing will help i sure as hell didnt.... good luck to ya
Old Nov 14, 2006 | 05:12 AM
04GIBBS's Avatar
Default help
Maybe you guys can help me out here. I had SW installed and eliminated the 02 sensors in the rear and I keep getting a check engine light. This has only happend in my 06? I have a Nelsons tune and we are on the second one and still have the check engine light. I know he can take care of it but I was wondering if any of you guys have experienced the same?
I have unplugged them both, the right 02 has been replaced with an inteceptor gauge.
SORRY to jump in like this.
Old Nov 14, 2006 | 07:33 AM
Moddoo's Avatar
Spy- The install is not too tough, if you search for a little bit, you will pick up a few good tips/experiances to help you avoid trouble.
Gibbs-
There is a P0054, and P0060 that are unlabeled on the DTC list. These need to be turned off when eliminating the rear O2s. He may not know this yet. Have you scanned to see what codes you're throwing?
Hope this helps.
Old Nov 14, 2006 | 08:53 AM
04GIBBS's Avatar
Default headers
Yes I had it scanned and these were the codes Subject: P0054, P0060,
P2A01. He knew about the ones you had mentioned the last is a new?
Old Nov 14, 2006 | 09:14 AM
Moddoo's Avatar
I forgot about that one,
P2A01 & P2A04 have to be deleted too.
P2A01 = O2 sensor circuit range/performance bank 1 sensor 2
P2A04 = O2 sensor circuit range/performance bank 2 sensor 2
Old Nov 14, 2006 | 10:06 AM
04GIBBS's Avatar
Default Exhaust
Thanks soo much
