installing front O2's
Old Jul 7, 2006 | 02:00 PM
OrlandoFL4.8's Avatar
Default installing front O2's
Just received some replacement front O2's since the one on the pasenger went out, I will be replacing both the driver and passenger front 02. Any thing special I should know, or is it just replace and go. These are the "Denso first time fit" and it looks like they both came with a one foot long -4 wire-wiring harness and a tube of anti seeze.
-Thanks
Old Jul 7, 2006 | 02:02 PM
LesPaul's Avatar
just un bolt and unplug the old ones and reverse for the new man.... have fun
Old Jul 7, 2006 | 02:27 PM
TigerFan187's Avatar
Replacing stock ones with stock ones is a piece of cake. It may take 30 minutes if you try to do it with your feet.!
After I did LT headers a while back the stock o2's werent cutting it for my setup so I had to put 02 Vette rear o2's in place of my fronts(the stock rears were removed with the cats) and that sucked bad. For whatever reason(probably just becuase I had to replace them ) the Vettes and trucks have different connectors so I had to do some splicing. Splicing isnt a big deal but for some reason the passenger side wiring had no slack to let out like the drivers side. So if you have to do this do your self a favor and get your truck in the air!
Old Jul 7, 2006 | 03:03 PM
bud8fan's Avatar
what do mean by the stock 02's were not cutting it with your setup after the lt's went on...were you getting codes or what.....
Old Jul 7, 2006 | 03:32 PM
Thanks everyone for help. I will be crawling under the truck first thing tomorrow, its raining right now and too dark in my garage.
Old Jul 7, 2006 | 03:49 PM
LesPaul's Avatar
one last word of advice cuz this happend to me.... it takes alittle force to break those things loose but when they do they spin really freely so watch your fingers when it breaks
Old Jul 7, 2006 | 03:52 PM
KySilverado's Avatar
It's common for heater codes on the front o2's with long tubes. Due to being further downstream and lesser heat retention of the headers. The applications for rear vette 02's have a larger/higher amp heater in them that seems to work in such cases.
Old Jul 7, 2006 | 03:57 PM
bud8fan's Avatar
ahhh...learn something new every day...
so if i change out my 02's with the vette 02's then these 2 codes will stop popping up...which year model 02's am i looking for....or a part number would be nice....
Old Jul 7, 2006 | 04:16 PM
ecthelion's Avatar
From: Formerly Hayden, AL . . . Now Attleboro Falls, MA
I just changed out the front O2s while my transfer case was out. Very easy . . . only tip I can think of is to use an automotive pick on the electrical connectors, where they clip to the body.
Old Jul 7, 2006 | 04:47 PM
RERICK's Avatar
Don't forget to put some anti seize (sp) on the threads. Just in case you want to get them back out.
Ron
