Installing cam soon..verify part numbers!
Originally Posted by 99Silver6.0
Front main seal??
12561244/12585673 - Front Crank Seal
this is the seal that is in the timing chain cover, correct? Just want to double check!
12559271 - Water Pump Gasket
12558013 - Timing Cover Gasket
12561244 - Front Crank Seal
12557840 - Crank Pulley Bolt
Originally Posted by xlcooplx
found these in the GM General Discussion Forum. They seem to match. Thanks for the help guys!
LSx valve seals (set of 8), intake = 12457652
LSx valve seals (set of 8), exhaust = 12533586
How many miles you got on your truck?? Get some valve seals too. Do it while your in there!!!!!!!!!
They are simple. When the springs are off. Grab the seal with a pair of pliers and pull it off. And replace. Use a socket that fits over it to drive it down.
ahh, okay. thanks!
edit: just ordered everything. soon shall be time to get this thing in.
iregret
Jul 27, 2015 10:32 PM
