Installing cam soon..verify part numbers!
Old Jul 7, 2007 | 08:43 PM
xlcooplx's Avatar
Default Installing cam soon..verify part numbers!
Going to install my 212/218 .531" 114lsa soon. I need the two water pump gaskets, a timing cover gasket, and the rubber seal around the crank snout that I am aware of. I also have to get the new bolt and longer bolt for the crank. Nothing else is needed correct?
Waterpump gaskets:12588372
Timing chain cover gasket:12574294
Does anyone have the part number for the rubber seal/gasket around the crank snout? Also, am I missing anything? Thanks in advance!
Old Jul 7, 2007 | 09:27 PM
v8
17,16,15,14,13,12,11 Drvr
you will need to get some black forma gasket for the timing chain cover at the bottom, how old is the truck, might want to change out valve cover gaskets as well.
good luck
Old Jul 7, 2007 | 09:29 PM
1TRUESS's Avatar
I am going to the dealership Monday for these same parts. Thanks for the numbers!
Old Jul 7, 2007 | 09:32 PM
xlcooplx's Avatar
oh yeah, forgot about the RTV! thanks again for the heads up.
no problem ben!
anyone else?
Old Jul 7, 2007 | 09:40 PM
1SlowHoe's Avatar
Destroyer of Transmissions
You have magnets for the lifters or wooden dowels?
New Springs?
Coolant
Beer
Old Jul 7, 2007 | 10:08 PM
xlcooplx's Avatar
New Springs?
Coolant
Beer
got the ls6 springs on the way! got the magnets for the lifters and the dowels from my buddy's previous cam swap! Thanks again man! Wouldnt happen to have the part number im looking for you, would you?
Old Jul 8, 2007 | 12:53 AM
silveradokidd_4518's Avatar
whats the part number for the longer crank bolt?
Old Jul 8, 2007 | 09:25 AM
xlcooplx's Avatar
hmm, glad you asked that. the bolt that i have currently is 12557840. I think thats the regular crank bolt though. anyone have the longer bolt part number?
Old Jul 8, 2007 | 09:31 AM
1TRUESS's Avatar
I would really look into getting one of these! I have one, but have not used it yet!
https://ls1tech.com/forums/showthread.php?t=391883
Old Jul 8, 2007 | 11:36 AM
xlcooplx's Avatar
just spoke with eric (hitmax), he's got one that im going to use!
