Installing 6.0 cam into a 5.3
Old 10-18-2017, 09:35 PM
1994Vmax's Avatar
It will work but it's a cam ground for rectangular port heads and not cathedrals..... why not get the 3 bolt sprocket and run an LQ4 cam...
Old 10-18-2017, 10:02 PM
Registered User
TexanTruck's Avatar
Because there is more cost involved, new timing chain set and I read the front cover would need to be changed as well. All I’m trying to do is delete the AFM, im not trying to build a race motor. I am going to install a L96 cam which should work out fine, $80 online. And good point on the L92 head difference. I did find the specs on that cam.
L92- 464/474 lift 196/206 Duration and 116 LSA
L96 cam part #12626660 (Flex Fuel Motor)
LY6 cam part #12629698 (Gas Only Motor)
Old 10-18-2017, 10:39 PM
swathdiver's Avatar
Beware of those cam specs for the LY6 PN# 12629698. I have that camshaft number listed as for the L76 which also uses the 12625438 which are AFM cams.
When I get around to tearing into my LC9, I'm strongly leaning towards the LY6/L96 12625440 which is 196 208 .467.479 116. That's as close as I could find after months of searching.
That being said, GMPP, BTR, Comp Cams, Cam Motion and Vinci all sell very mild, low lift cams for our motor but nearly all are Gen III style. All are between 203 In - 216 EX duration, none over .530 lift and 113-117 LSA.
The LM7 is definitely not equal!
The 12561721 in the LQ4 and LQ9 would be an equivalent Gen III camshaft.
Old 10-18-2017, 10:53 PM
1994Vmax's Avatar
Yeah if you keep the vvt the L96 will work... It's not ideal but it's so puny it won't really matter and it's not really any different than the LQ4 cam beyond the vvt aspect. Finally finding it's specs I really should put a cam in my 17 HD lol.
Old 10-18-2017, 10:57 PM
Registered User
TexanTruck's Avatar
I’m searching Auto Trader for vin numbers for 2007-2015 Sierra 2500 trucks then I go here https://service.gm.com/dealerworld/vincards/
For the engine type (L96, LY6, etc) then I go here https://www.gmpartsdirect.co/
and input that same vin # to look up cam part # and that is what I’m coming up with. Great input thanks.
The L92 specs came from Crower Tech Support. Im waiting for a response for the LY6/L96 cam specs.
Old 10-18-2017, 11:09 PM
swathdiver's Avatar
A non VVT GEN IV motor can run a VVT Gen IV camshaft without any modifications.
My pleasure TT!
Old 10-18-2017, 11:16 PM
Registered User
TexanTruck's Avatar
My pleasure TT!
Timing set will need to be changed. Mine is a VVT motor, can I run a Non-VVT cam without any modifications?
Old 10-18-2017, 11:41 PM
swathdiver's Avatar
No, the 2nd journal has a groove and holes to lubricate the VVT components. But if you removed the VVT, then yes, you could run a non VVT Gen IV or Gen III camshaft.
I like the idea of VVT and it is certainly more reliable than AFM. I've disabled AFM and next year or so will remove it physically from the LC9. My LC9 does not have VVT, it's a 2009.
Old 10-19-2017, 01:08 AM
01FormulaTA's Avatar
I’m searching Auto Trader for vin numbers for 2007-2010 Sierra 2500 trucks then I go here https://service.gm.com/dealerworld/vincards/
I have an L96 cam with 35k miles out of a 2015 2500 Silverado I would let go for cheap, where are you located? PM me if interested
Old 10-19-2017, 06:48 AM
Registered User
TexanTruck's Avatar
So when I researched that cam p/n 12625440 that you came up with I see it is used in the 2009-2013 Suburban/Yukon XL in both the LY6 Gas (2009-2010) and L96 Flex Fuel (2010-2013) and 2010 only Silverado 2500/Sierra 2500 L96 Flex Fuel motors.
But the 2007-2009 Silverado 2500/Sierra 2500 LY6 Gas and 2011-2015 Silverado 2500/Sierra 2500 L96 Flex Fuel motors are using cam p/n 12626660...
The LY6 and L96 where both produced in 2010. Not sure what determined which got what? Probably just a transition year.
None the less I'm not sure what the difference is between the two cams but I'm sure it's minor and both cams should work. The 12626660 cam is about $40 cheaper!
