Installed LS1 E-fans
Old Jul 25, 2007 | 09:44 AM
mabutler's Avatar
Default Installed LS1 E-fans
I finally installed my LS1 e-fans this weekend after they sat in my garage forever. I used a harness from DLH2006 that is put together very nicely. I did have to switch around the wires because my fans were spinning backwards and also lengthen one wire, but it was no big deal. The fans just sat into the bottom radiator tray and I secured the top with the body lift brackets used for my fan shroud. The only problem I have now is that they are extremely loud and I suspect the left motor might be the problem so I am looking into replacing it. Here are a couple pics of the installation.
I can tell a big differnce in throttle response and low end torque, hopefully they will improve my milelage also.
On a side note, if you ever say to someone, "just make sure you don't drill through my radiator", go ahead and plan on replacing it.
Old Jul 26, 2007 | 12:29 PM
SS_bnoon_SS's Avatar
Looks decent, just trim off that L O N G bolt sticking out and paint the brackets black and it should look nice.
I installed mine "upside down" compared to yours though so that the wiring is at the bottom and looks more factory compared to having the wires on top of the motors.
Old Jul 26, 2007 | 12:45 PM
truckmann's Avatar
Ya I installed mine the other way around too, but hey whatever works.
Old Jul 26, 2007 | 01:16 PM
Lord Aries's Avatar
Wow! I guess mine are upside down too then, I put them with the wires at the bottom of the fans because the Force told me too. LoL
thunder550
Oct 8, 2015 04:53 PM
axekick
Sep 7, 2015 07:01 PM
nrmskate
Aug 11, 2015 02:44 PM
Denali08
Aug 9, 2015 04:34 PM
Black-Syde
Jul 6, 2015 02:12 PM
