Install Questions
Old Jan 24, 2006 | 08:54 PM
phasemaster1's Avatar
Default Install Questions
I Have Several Questions, I Going To Do A Cam Install Just Waiting On Cam And Springs. I Read Some Where That To Install The Crank Pulley You Can Place It In The Oven To Heat It Up And Makes Install Easier Is This True And Has Anybody Done It? Please Temp And How Long? What Air Pressure Do Is Recommended To Keep Valves Up While I Change The Springs?last But Not Least What Is Easiest Way To Remove And In Stall Fan From Water Pump? Ran Out Of Money So I'll Do Electric Fans Later. Thanks Going To Try The Oldman Cam From Thunder 214/220 .600/.525 Crane Dual Valve Springs And New Pushrods Ls2 Chain And Ported Oil Pump.
Old Jan 24, 2006 | 09:08 PM
v8
17,16,15,14,13,12,11 Drvr
well on the under drive pully, never heard of heat, just buy a longer bolt to put it on, you need at least 60psi to hold up the valves, set the regulator at 80psi to be safe,best way to get the fan off is to use a large cresent wrench, sit it on the nut and strike it with a hammer, like your trying to force the wrench on the nut, this will break the lock tight, when putting it back together use lock tight (blue) and snug up fan then use hammer and wrench to sinch it down. Have you ever done the cam swap before? no need to remove a/c, heads, intake like the book says.
go to www.ls1howto.com , good luck.
Old Jan 24, 2006 | 09:18 PM
Nope This Will Be The First So I Need Luck I Have A 6.0l On A Stand And I Practiced On It But In Car Alot More Difficult I Bet. About The Fan Do I Leave The Belt On Or Not? Not To Clear On That Part. Other Engine Has It Removed A Friends Buddy Removed It And I Wasent There. I Know Why Not Use 6.0l In Truck Well Only 60,000 Miles And My 67 Gto Would Look Good With It Thats Another Story.
Old Jan 24, 2006 | 09:39 PM
AintNoHo's Avatar
The heat thing is for a harmonic balancer because it is pressed-on the crank nose. (200 degrees-20 minutes-use wifes ovenmitts) Pulleys just bolt-on.
Old Jan 24, 2006 | 10:01 PM
v8
never had to use the oven method, but if it works go for it. Yes leave the belt on, it will help hold the fan in place.
Old Jan 25, 2006 | 09:55 AM
kerryt1's Avatar
I just used a handheld propane or butane torch...."Bernz-o-matic" type blue bottle thing. Heat up the inner part of the balancer for a couple of minutes, the thing slides right on...but you gotta be quick about it.
Denali08
Aug 9, 2015 04:34 PM
USMCvet0311
Aug 1, 2015 07:45 AM
sauldgold
Jul 23, 2015 02:15 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
