Install oiul pump Dry?
Old Jun 2, 2010 | 09:18 PM
Big Port Jimmy 6's Avatar
Default Install oiul pump Dry?
Do I need to do anything to my new oil pump before I install it? Jay
Old Jun 2, 2010 | 10:06 PM
hirdlej's Avatar
I always tip them upside down and pour oil in the pickup tube port, then rotate by hand until it pumps out. Use some thick oil though so it doesn't run out while you're installing it. I use bar and chain oil from my chainsaw. There's nothing wrong with having a little bit of it in your engine
08k1500_3's Avatar
what style engine are you working on, if it is an old style 5.7 I just fill the pump with clean oil and let the excess run out, if new style 5.3, 6.0...... same thing just give the pump a fresh coating of oil and spin it around a couple times then you are good to go
Old Jun 2, 2010 | 10:28 PM
Whoops shoulda said it was on the 5.3. Jay
thunder550
Oct 8, 2015 04:53 PM
MS3Z
Jul 30, 2015 06:17 PM
Ammadien
Jul 22, 2015 08:50 PM
lxcoupe
Jul 21, 2015 02:12 AM
