Injectors... will I need them?
Old Feb 1, 2011 | 09:20 PM
dmelvin's Avatar
Default Injectors... will I need them?
I was just having a thought... let me know what you guys think.
I've got a stock 5.3... plans are as follows:
Milled 243's from LS6 (sodium filled valves and the such) CR bump to about 10.15
216/220 Comp Cam
LT's with full exhaust
2600 - 3000 converter
Planning on spinning it to 6400-6600
Do I need to be thinking of injectors at this point? if so, should I be looking at 31's or Marine 8.1's (42 I think). The 42's would give me a bunch of head room for possibly a boost project in the future, I don't know if the 31's are enough, or if I even need to be worrying about swapping them when I do my build.
Old Feb 1, 2011 | 09:25 PM
Atomic's Avatar
I have a gauge for that
Pretty close to maxing them out. 32s would be the next step.
Old Feb 1, 2011 | 09:30 PM
dmelvin's Avatar
Those would be the 8.1L truck injectors right? I'd rather run a set of 32's at 65-70% than mine at 90-95% or whatever the hell it would be, point is, if I'm going to be that close, I'd rather move up.
Old Feb 1, 2011 | 10:57 PM
1slowz71's Avatar
I dont think youll need them i was running my stock 5.3 injectors on a 6L cammed for a while for the record the 5.3 and 6L are the same 1s, i dont think youl need them!
Old Feb 1, 2011 | 11:16 PM
Mangled03gmc's Avatar
Baltimore Whore
At a minimun, to be on the safe side the stock 8,1's is what I would do, just to keep the IDC's down. The stock ones could do it, but would be working hard..
Old Feb 1, 2011 | 11:27 PM
dmelvin's Avatar
That's kinda the way I felt, I didn't know how close I'd be to maxing them.
Thanks for the input guys
Old Feb 2, 2011 | 03:28 AM
05gmcsierra's Avatar
Fml does this mean ima need more injector? 222/226 cam on a 5.3 spinning it to about 6500..??? I'm assuming its a yes.. ill b getting the 32s then
Old Feb 2, 2011 | 04:04 AM
LS1TRUCKGUY's Avatar
mods in sig. spinning mine to 6850. my injectors are at 99% idc
Old Feb 2, 2011 | 11:10 AM
grey matter 04's Avatar
13 Second Truck Club
i would put injectors in it
Mine is 95-100% duty cycle at high rpm with a 212/218
Old Feb 5, 2011 | 05:41 PM
02'Z71ONDUBZ''s Avatar
my bro is at 102% IDC with a 5.3, TSP 220 cam, headers and cai shifting at 6500
