injectors??
Injectors by themselves won't give you any gains. As you do more mods, such as cam or heads, larger injectors may then be required. You would be able to notice this by observing your injector duty cycle with the proper tuning sofware. The 8.1 injectors (29.9lb = gas, 42lb = Marine) are a direct fit that only require PCM tuning to work.
shootermwc
Oct 8, 2015 01:45 PM
