Injectors ?
Old Jan 26, 2009 | 09:52 PM
1andOnly's Avatar
Default Injectors ?
I have a 04 5.3 silverado will 8.1L injectors be a direct fit or will have to buy pigtails Thanks....
Old Jan 28, 2009 | 12:05 AM
Ender06's Avatar
99.9% sure they are direct fit.
Old Jan 28, 2009 | 03:57 AM
LowBlack99's Avatar
Direct fit. Make sure you get the Marine injectors if your wanting 42#. I believe the part # is 17113739, you can search to find out for sure, I'm looking at a blurry pic I took.
Old Jan 28, 2009 | 10:13 AM
1andOnly's Avatar
thanks alot I found some truck injectors for cheap Im trying to clear up some codes an Ill start with the injectors.....Kevin
Old Jan 28, 2009 | 10:19 AM
kbracing96's Avatar
You do HAVE to tune for them though
Old Jan 28, 2009 | 11:26 AM
OnyxSilveradoSS's Avatar
on the same topic:
does anyone have the info about re-flowing 42's to 60?? I read a company was doing it and the cost was way less than dealing with new injectors.
Old Jan 28, 2009 | 03:55 PM
kbracing96's Avatar
Originally Posted by OnyxSilveradoSS
on the same topic:
FIC Injectors over on LS1tech.
Old Jan 28, 2009 | 05:34 PM
tybardy's Avatar
forgive my ignorance guys.... noob chiming in here.... if you want to point me to a different link/thread thats fine too...
why would you want the 8.1 injectors? what is 42#?
Old Jan 28, 2009 | 05:41 PM
95 bright teal's Avatar
When you start to push the performance of the motor, you can easily push the stock injectors past what they can efficiently/safely do.
Any type of Forced induction will need bigger injectors, and those running large a large cam/heads.
stock injectors for the 5.3's are rated at 26#(or 28# cant remember for sure, but its not enough)
nice thing about 8.1l injectors they can be found for cheap
Old Jan 28, 2009 | 05:43 PM
tybardy's Avatar
at what point during the modification process would you need bigger injectors? obviously im not there yet (all i have is an intake setup) but next is the muffler and LT's and after that is a tune and Cams
