Injectors
Old Apr 27, 2005 | 02:04 PM
Default Injectors
i have my computer set at 32lbs the only thing i can find aorund here is stock 26lbs and bosch 36lbs what would happen if i run the 26lbs injectors please help
Old Apr 27, 2005 | 02:32 PM
BigTex's Avatar
You'd be dangerously lean and would probably damage something if you did it for an extended amount of time.
Old Apr 27, 2005 | 03:41 PM
IT WILL ONLY BE FOR A COUPLE OF MONTHS. WHAT WILL HAPPEN IF I PUT THE 36LBS IN.
Old Apr 27, 2005 | 06:20 PM
litreddevil's Avatar
Banned
you will run rich and if you have cat it will fry them,"that might be a good thing give you a reason to get rid of them"
Old Apr 27, 2005 | 09:36 PM
Texas Terminator's Avatar
11 Second Club
nope. other way around. like big tex said. and a lean condition would fry the cats, that's what the COT setting is for(secondary O2's), if it goes too lean, it dumps more fuel to keep the cats from overheating.
Old Apr 27, 2005 | 11:03 PM
I belive the 6.0 injectors are 30lbs. I sold a used set on ebay for $70. Also you may be able to use the fms 24lbs injector, at our 45psi the should be around 30lbs.
Old Apr 28, 2005 | 08:26 AM
I Have No Cats Or Egr Valve
$A_Money$81
Mar 27, 2023 10:25 AM
shootermwc
Oct 8, 2015 01:45 PM
KleanKustoms
Sep 30, 2015 05:07 PM
Wrecker 426
Sep 29, 2015 11:00 PM
sTNT971
Sep 26, 2015 04:22 PM
