Injector Selection
Old Jun 12, 2006 | 01:31 PM
Rhino79's Avatar
9 Second Club
Default Injector Selection
I'm just wondering which injectors to run on the 408. I originally was going to say 42lb but I have seen a lot of F-Body guys with very similar setu[ps running 36lb injectors. The setup is your typical 408 with 6.0l heads and upper 230 duration cam with about .600 lift. The motor will have some spray too, 200 or less though. Thanks for any help guys.
Ryan
Old Jun 12, 2006 | 06:42 PM
Quik's Avatar
5 year bitches!
36# are fine for N/A 42# for alot of juice if you ran a dry setup
but if youre using a ford injector remmeber they are now higher at higher psi's. a 30 is a 36 roughly.
Old Jun 12, 2006 | 07:20 PM
Rhino79's Avatar
9 Second Club
It's a wet setup so it looks like 36's will be fine then. Thanks!
carid
Oct 28, 2015 08:24 AM
alex226
Oct 14, 2015 07:23 AM
OHsixLS3
Sep 25, 2015 11:20 AM
FlowmasterMufflers
Sep 18, 2015 02:31 PM
zblee
Sep 17, 2015 07:58 AM
