Injector ? Needing some help!!!!!
Old Dec 29, 2008 | 07:52 PM
You need to get a 04 up fuel rail. Right now you have two fuel regs. The one on the rail and the one in the tank.. You need the rail that is for a returnless system.. The injectors you have will work with a returnless rail.. If your talking about the T looking fittings on the bottom, yes that is just a coolant bypass he did.. I think you will be ok if you just change one rail out
So just change the right side out, right?
Old Dec 29, 2008 | 08:17 PM
Mangled03gmc's Avatar
Baltimore Whore
Yes, but try to get another opp on it. I am pretty sure both rails will work on the crossover..
Old Dec 29, 2008 | 10:20 PM
Sorry, What is "opp". You may have to explain everything a little easier. I am a little new to the "LS" series....
Old Dec 29, 2008 | 10:26 PM
Baltimore Whore
Opp is opinion sorry bout that.. Like I said, a returnless rail shoul work for ya
Old Dec 29, 2008 | 10:38 PM
Oh. Ok. I guess I didn't read that right. So I should just be able to to replace the driver side right? I will def get some more opp on it. Thanks!
Old Dec 29, 2008 | 11:01 PM
Baltimore Whore
Yah I think that will fix it.. You have two fuel pressure regs hooked up now.. Hell you might be able to pull the vac line off the one on the rail, plug the hole on top of the intake, but that might not work..
Old Dec 29, 2008 | 11:05 PM
What do you mean. I am up to try anything.
Old Dec 29, 2008 | 11:15 PM
Baltimore Whore
Now that I think about it, just try to find a returnless driver side rail...
Old Dec 29, 2008 | 11:20 PM
Ok. Will do. Thanks for the help.
ZONES89RS
21
Sep 24, 2015 05:58 PM
Bluecollar Hotrods
Jul 16, 2015 08:52 PM
Aboss
Jul 9, 2015 10:28 AM
Sbrown06
Jul 9, 2015 09:21 AM
