Injector ? Needing some help!!!!!
You need to get a 04 up fuel rail. Right now you have two fuel regs. The one on the rail and the one in the tank.. You need the rail that is for a returnless system.. The injectors you have will work with a returnless rail.. If your talking about the T looking fittings on the bottom, yes that is just a coolant bypass he did.. I think you will be ok if you just change one rail out
Yah I think that will fix it.. You have two fuel pressure regs hooked up now.. Hell you might be able to pull the vac line off the one on the rail, plug the hole on top of the intake, but that might not work..
