info needed on injector size?
Old Apr 30, 2007 | 10:33 AM
LARRY01Z28's Avatar
Default info needed on injector size?
where can i find for sure what size injectors my truk has. its a 99 silverado with a 4.8 L
i just put in a 5.3 L but used my intake and injectors.
i was told 99 is different from all other years?????
Old Apr 30, 2007 | 11:25 AM
Dude if I'm not mistaken I think they are 20lbs. per hour.
Old Apr 30, 2007 | 11:53 AM
LARRY01Z28's Avatar
and the newer ones are 24 lb??
Old Apr 30, 2007 | 11:54 AM
dirt track racer 81's Avatar
Old Apr 30, 2007 | 04:24 PM
24 OR ACTUALLY 25 I THINK. I GOT THE 25LB. DELPHI SPRAYERS IN MINE.
Old May 2, 2007 | 03:24 PM
bgray's Avatar
TOTM: June 2007
24s are in a 5.3...not sure about the 4.8 however..id imagine the exact same..jsut changed in the tune
for reading sake....if you ever plan to upgrade..the 8.1L truck motors run 31-32 pound injectors that are a direct plug in for out harnass's..most other fuel injectors like SVO's and LSx injectors use a different connector...so 8.1L ones are the way to go!
Old May 2, 2007 | 03:43 PM
budhayes3's Avatar
PT's Slowest Truck
From the info that I've gathered here, the 99's are different and flow less than 00 and up...I believe the numbers are 21lb vs. 24.7lb or something like that. The 4.8 and 5.3 use the same injectors.
ZONES89RS
21
Sep 24, 2015 05:58 PM
Bluecollar Hotrods
Jul 16, 2015 08:52 PM
Aboss
Jul 9, 2015 10:28 AM
jrplz
Jul 9, 2015 12:07 AM
