Inerest in Pacesetter Long tube headers?
#52
That bottom tube still looks awfully close to the rail. Are you sure it isn't touching or banging?
Where in TX are you? Have you put a scan tool on it to see if your getting any KR from it?
#53
Could you maybe lay under the truck and take a pic of the pass side header from there?? Sorry to be picky! Thanks for the pther pics though.
#54
#57
11 Second Club
I looked at my passenger side header today and it looks fine. About a 1/4 inch or less between the frame and header and about 1\2 away from the tranny lines. I wonder if the header gasket they sent with the kit is to think and pushes the header out a little farther . I re-used my stock gaskets which were alot thinner then the paper one.
#58
#59
Stupid question, but I'm assuming that they get run under the tranny crossmember, right? Reason I ask is, while I have my truck on the lift, I was looking at it and trying to firgure it out. Also, how far back along the frame do they go? How close to the crossmember is the collector?
#60
