im stumped, need help
Ok well I fixed the fuel leak. But with the return line hooked up its causing a lot of turbulence in the fuel bucket, (like a ton of small bubbles.
Idk if that will cause an issue. I drilled the bottom of the fuel return plastic piece out like I read I had to do. Maybe I did it to big??
Also increasing the pressure at the regulator didn’t help but it only is rated 40-75psi so may still not be enough. Any thoughts?
Sounds like air in the system but I can't picture how air would be ingested into a pressurized system, if I had vacuum on it anywhere it would pull air in from atmosphere if there were a leak.
So I don't know man, I've never watched a fuel return into a bucket so it may be okay....?
