I'm getting an ABS and BRAKE warnings lights
They've come on two times in the last week and a half, both ABS and BRAKE warning lights. They appeared when I started the truck up. I don't see any fluid around the wheels, and the brake resevoir is full. What gives?
i belive that there is a recall out on this! the ABS sensor has something wrong with it that they have to replace them!! or something like that...i have the recall at my house so ill check it when i get home from work!!!
That didn't happen to start around the time of your gear or tire size change did it????
Just FYI, I had ABS and Brake warning lights every 3rd start up right after my gear change. It's actually a "wheel speed sensor mismatch" code. Replacing the module or any other ABS parts will do nothing for it. The speedometer was calibrated and the lights never have come back on
all that is done for the recall is clean the rust from around the wheel speed sensor, and applying some anticorrosion paint to the sensor mounting surface... Like colby said if you changed gears, you have a mismatch in the wheelspeeds causing your light...
