Ignition Upgrades, cam, and rockers
Old Dec 1, 2005 | 01:27 PM
virgils4.85spd's Avatar
Default Ignition Upgrades, cam, and rockers
I have a 4.8 that is a lil hesitant when i gas it. Should i do an ignition upgrade? If yes who makes a good one, and what should i get? AND im going to be getting a cam soon. Who else makes a good drivable cam with a decent lope NOT STOCK besides the ones in the cam thread. I just want some lope and mid to hi end power, but i drive it every day. I also need to be able to drive it 2 hrs to get it programmed at futral motorsports. So it cant be to where i cant drive it until its programmed. I need some advice.
Thanks,
Derek
Old Dec 1, 2005 | 07:21 PM
99Silver6.0's Avatar
Thanks,
Derek
There really is no ignition upgrade short of changing plugs and wires. MSD soes make a new coil but youll spend out the *** for some pretty red useless coils. Thunder Racings 220/220 is a pretty nice cam and has a nice lope. My 212/218 had a fair amount of lope for a 114LSA cam. Either of the cams I mentioned will run with no tuning. The 220 wont run spectatular without the tune but you can get to Futral. You will need valve springs to go with that cam too. The Comp 918's will work fine.
Old Dec 1, 2005 | 10:36 PM
Default thanks
thanks man i appreciate it.
Old Dec 1, 2005 | 10:37 PM
Default i forgot to ask
will i need pushrods and lifters too?
Old Dec 1, 2005 | 11:16 PM
I would get some hardened rods too. Stock lifters are fine.
maxspeed05V
Jul 19, 2015 07:08 PM
Suburban2500
Jul 19, 2015 04:50 PM
N/ALS1
11
Jul 13, 2015 10:56 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
supersportsteve
Jul 4, 2015 12:02 PM
