if bigger is better, anyone stuffed an 8.1 in a halfton
Do everything parish8 does, we need everything the same in the world.
Bryan TTM: Build it up right, forget the SC, and go turbo, then boost it to the moon. Pretty smoke any small block around.
As he said NO REPLACEMENT FOR DISPLACEMENT.
to whoever says a blown sbc bolt on buy off the shelf will always smoke a cammed/ported BBC...YOURE CRAZY...some of us have & are quite capable of makin over 1000 hp with a BBC, waayy over 1k...so dont bet the farm on that one, dude
I dont see a stock bottom end big block with a head and cam package running more than 450-500 rwhp on the street. A properly tuned boosted small block will make more than that.
Isn't adding a blower or turbo adding more displacement in a way? Engines are air pumps--by increasing the bore and/or stroke, you're adding more capacity for air. By using a turbo or blower, you're forcing more air into the motor, which in a round about way is increasing displacement. Right?
I would LOVE to do a big block--if for nothing other than the sound a good cammed big block makes. I saw a nice 8100 at Turkey Rod Run this weekend for $4500. It definitely got the wheels turning.
Torque is what we need to get this heavy trucks moving, and a big block will provide that in spades. I say go for it!!!
Its worth not the work. The LSX motors breathe so well and make so much power per size its not a worth while swap when you can drop in a direct fit 6.0 with a few bolt-ons that will make more power for less effort.
Do it nubi!
Then when you are making the same poweer as I am but getting 8mpg, can't smog, and find out it cost you double what it would have cost with the smaller cubes don't come crying to me.
Pipe dreams, pipe dreams.... 2 of you in particular crack me up because you run your mouths and don't have **** to back it up.
I sense some immature attitudes in here so I'm in a mood to sling my own.
