idling problem??? HELP
Old Oct 13, 2009 | 02:37 PM
LaCamionetaGris's Avatar
Question idling problem??? HELP
it all started with my girl leaving the fog lights on while she was working and discharged the battery completly....then the idling problem started, when i start up the truck the idle bounces up down @PARK, when i shift to DRIVE it settles down ok...but when i turn on the AC the idle bounces below normal and the truck shakes and makes a noises somewhere around the motor, even some times the truck turns off? wtf...
any suggestions what the problem could be...
Old Oct 13, 2009 | 05:06 PM
Daryn's Avatar
Formerly darynC-10/23/10
check el tune'
Old Oct 13, 2009 | 05:34 PM
Wheatley's Avatar
Truck Sponsor
Sent you a pm to help.
more than likley it is not a tune related issue,seeing it is a stock cam and has been fine in the past.
Old Oct 13, 2009 | 08:11 PM
budhayes3's Avatar
PT's Slowest Truck
If the battery went totally dead the PCM may just need to relearn the idle...
Tydriver
45
Oct 23, 2015 09:19 PM
Shotguntommy
Sep 15, 2015 05:24 AM
Pimpinpete
Sep 8, 2015 07:39 PM
custm2500
Sep 8, 2015 05:53 PM
mayko
Sep 7, 2015 12:24 PM
