Idle? Whistle? What?
Old Jan 8, 2008 | 05:21 PM
ThrottleHappy7's Avatar
Question Idle? Whistle? What?
Try this one. I replaced my valve covers and gaskets, then I start my truck and it doesn't want to idle -barely or not at all-... and then my carb starts whistling like crazy...? Either there is something that I'm missing or it's just a coincidence that this happens at the same time. Any thoughts? I'm thinking idle mixture, but I don't know about the whistling.
Looks like the gremlins are striking back, again.
Old Jan 8, 2008 | 05:24 PM
ramsey rider's Avatar
i had it happen 1nce on a holly .i cant ramember what the heck it was .air breather?or air fuel mix?just letting ya know they do ,do it
Old Jan 8, 2008 | 06:16 PM
Mines a reman. Rochester Q-jet. It's been working just fine, and that's what makes it all the more puzzling.
Old Jan 8, 2008 | 06:55 PM
no punt intended but it sounds like you got a vaccum line mixed up or unhooked .
Old Jan 8, 2008 | 07:06 PM
That's what I was thinking, but I've checked the lines. I'll go back and triple check them again just to make sure. Unless I pulled one off by accident, the only one I know of that might be giving me a problem is the line that goes into the back of the carb. I had to undo it to get my valve covers off, but I made sure it was snug when I put it back on.
Old Jan 8, 2008 | 07:27 PM
make sure none are cracked or split from dry rot also and cracked when u moved them .pvc out ?if u have 1.it has to be rlated too vaccuum the valve covers wouldnt do it ,unless 1 came out of place maybe.but likely u would be losing oil .if on top when u put in they like too drop down.good luck
Old Jan 10, 2008 | 08:48 PM
Found that I was sucking air under the EGR, thus the high pitch whistling... and probably the reason it wouldn't idle.
Old Jan 14, 2008 | 07:34 PM
Problem's solved, and now she's running better than before... amazing what some gaskets and sealer can do.
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
BlownHD
Oct 3, 2015 12:24 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
