idle problems
Old Nov 3, 2005 | 06:46 PM
Badmire68's Avatar
10 Second Club
Default idle problems
I have a 01' 6.0L 4x4. I haven't had it very long but ever since I bought it the idle has been really low. It idles around 400rpm in gear and sometimes when backing up it will die on me. wondering if anyone else has had this problem?
Old Nov 3, 2005 | 10:07 PM
SLO-LS1's Avatar
Have you tried changing your idle air control valve? I think that's what it's called. On your throttle body, by the TPS. My 99 did the same thing, and that is what finally fixed it.
just my .02 - good luck
Old Nov 4, 2005 | 04:39 PM
Badmire68's Avatar
10 Second Club
thanks, I kinda figured that was the problem but I wanted to get some opinions before I started replacing parts.
Old Nov 4, 2005 | 05:41 PM
budhayes3's Avatar
PT's Slowest Truck
You could try cleaning the throttle body first and see if that helps. If the throttle body and passages for the IAC are gummed up with carbon, it will create idle and runability problems.
Old Nov 5, 2005 | 11:16 AM
Bish's Avatar
Ditto on cleaning the TB and IAC. The idle control is mounted to the TB and is super easy to remove and clean. I have been cleaning the TB since about 25K but started to have surging idle. Turns out the plunger for the IAC was equally crusted with black gunk. Some just remove the complete throttle body to clean it on a bench. After you are done, you should perform the Idle Relearn procedure.
Engine up to temp.
Block wheels
Start and put in D for 5 minutes
Put in Park for 5 minutes
Shut off.
That straight from my Helms Manual
Old Nov 8, 2005 | 08:07 PM
Badmire68's Avatar
10 Second Club
cleaned the idle control valve and idles perfect now. thanks for the help guys!
Tydriver
45
Oct 23, 2015 09:19 PM
Shotguntommy
Sep 15, 2015 05:24 AM
Pimpinpete
Sep 8, 2015 07:39 PM
custm2500
Sep 8, 2015 05:53 PM
mayko
Sep 7, 2015 12:24 PM
