Idiot of the year award goes to me!
Old Nov 20, 2024 | 05:56 PM
PowellSixO's Avatar
Hopefully this video works
File Type: mov
Old Nov 20, 2024 | 08:31 PM
1redta's Avatar
Originally Posted by strutaeng
I wonder what service manual says about that cam retaining plate? 🤔🤷
Almost sounds like we should advocate for a "non-reusable" philosophy for that one, no?
replace every time! it is to cheap to pass
Old Nov 21, 2024 | 09:43 AM
TXsilverado's Avatar
I advocate for replacing. It's too cheap to be sloppy. With that said i've reused them a few times and never had an issue. it's a roll of the dice.
Old Nov 21, 2024 | 09:53 AM
strutaeng's Avatar
5 Year Member
I checked and it doesn't really say that retaining plate must be replaced. I would agree with everyone else and say to just go ahead and replace it. IIRC, it's like $16 or something.
And the issue is that if leaks, you won't know it because it's behind the front timing cover, so you will probably never realize it's leaking and will cause oil pressure drop.
Old Nov 24, 2024 | 02:44 PM
1redta's Avatar
I did something dumb yesterday. I put some BTR valve covers with ignition mounts on my truck and had flipped the coil wiring harness where that side was “backwards”. When I started up the truck it was backfiring and running like a$$.
had to redo the everything in the truck cause I didn’t want to disturb the valve covers
Old Nov 25, 2024 | 12:44 PM
I flipped the coil harness backwards when installing dominator EFI. You're not alone.
Oldtruckin
Apr 4, 2019 11:09 PM
01GMC5.3
Dec 1, 2010 12:27 PM
Sinr98
Sep 10, 2010 09:33 PM
lukesdad04
Apr 6, 2009 05:25 PM
1slow01Z71
34
Jan 1, 2007 10:42 PM
