ideas....
Old May 20, 2011 | 11:35 PM
gmc6.0's Avatar
Default ideas....
since i upgraded my heads, with a trick front mount and upgraded fuel system what would be a smart decision to save for a forged block or just get a cam and meth kit...this is my daily driver and gas mileage is of some concern, also what is a good timing chain, as well as lifters..
Old May 21, 2011 | 02:48 AM
06Sierra2's Avatar
What size turbo is that and how much boost are you running? There are alot of people running decent boost on stock internals. What size motor do you have? Ls2 timing chain and Ls7 lifters.... If you arent running huge boost, depending on mileage of the current motor, a blower cam sounds like a nice upgrade.
Edit: just seen your screen name. Im guessing its a 6.0?
Old May 21, 2011 | 08:29 AM
gmc6.0's Avatar
i plan to run 12lbs right now its at 8 does any one have part numbers for the lifters and timing chain the motor is a 6.0 and a t76 turbo
Old May 21, 2011 | 09:18 PM
brent1976's Avatar
11 Second Club
You shouldn't need meth at 12psi. I run 16psi on 93 with no issues.
If you are planning on running 12 at the most, I would get a lighter spring for your wg, so you can get a boost controller. I can run 8.6, 12, or 16 psi at the push of a button. Put a 5lb spring in it, then you can turn it way down when it's as a dd, and turn it up when it's time to play. A different cam is probably not going to help on the milage part though.
Old May 24, 2011 | 12:01 AM
gmc6.0's Avatar
hey brent what is your gas mileage if you dont mind me asking
OceanStateTuning
Oct 16, 2013 01:15 PM
kazfan30
Oct 23, 2010 07:18 AM
tdub_23
21
Aug 10, 2010 09:22 PM
BlackPearlZ71
Feb 22, 2010 08:57 PM
jarrettbailey
Aug 25, 2008 10:06 PM
