IAT Sensor Relocate with Pics
Old 06-29-2010, 11:26 PM
  #21
Mrgoodwrench3's Avatar
Originally Posted by SILVERADO11
Real clean install, nice work! I have wire connectors at my work that are like the ones you used, ours have solder in the center that melts to make good conection to both wires, also has the shrink wrap on both ends.
Yes I have those too. They work Great!
Old 06-30-2010, 01:04 AM
  #22
How do I change this text
Wilde Racing's Avatar
Originally Posted by j_ahlheim
forgive my stupidity but what does it do different moving it from the maf to the pipe a foot away? I got a intake setup like yours so i'm curious.
Originally Posted by MustangPunk
I will be installing a relocated IAT sensor into my EGR block off plate sometime soon..
That is where I had mine. I move mine because of two things. One, F the stupid maf and the truck it rode in on. And two I wanted it after the meth nozzles.
I would be if you yield better (or worse) performance out of move your IAT around, your VE table is way out. Especially if the PCM is using complex cylinder charge logic....
Old 01-26-2011, 09:05 PM
  #23
BadAssChevy327's Avatar
Did this mod today using same parts. Clean install. Used a datalogger before and after and the drop was amazing compared to before. Now I need to figure out a way to get cooler temps. This hot air intake sucks
Old 01-30-2011, 11:54 PM
  #24
milkey57's Avatar
Did ths today too, but I actually put the sensor in the rubber base of my cai (where the tube meets the filter) what a difference it made temp wise. We did it while she was on the dyno jet too...saw a 3rwhp gain from something so simple!
Old 01-31-2011, 12:38 AM
  #25
2004SSS's Avatar
if anyone wants one of these for a k&n fipk i have one with the sensor all ready to go .
Old 08-31-2011, 12:53 PM
  #26
11 Second Truck Club
Superado's Avatar
This is another good thread w/ links to three others on relocating the IAT sensor to the GM EGR block-off on the intake, just behind the TB.
https://www.performancetrucks.net/fo...at-mod-404701/
Old 09-08-2011, 09:09 AM
  #27
hog
hog's Avatar
Interesting.
On my 97, the stock IAT is divorced from the 75mm aluminum body MAF.
My Marine Intake uses a combined IAT/MAP sensor that sits in teh top of the upper plenum. The stock truck sensor is simply a MAP sensor, so I removed the marine IAT/MAP combo and am running the truck MAP.
I have a new 85mm plastic body truck/01+ Vette MAF with an integral MAF/IAT sensor.
I bought the MAF/IAT leads for an LS6 Vette and got 5 of those cool butt connectors with the integral sealant.
So I have 3 options for IAT
1)Integral MAF/IAT
2)Divorced IAT in air intake tube
3)IAT/MAP combo that senses actual air temp inside the plenum.
I wonder if there is really a difference beween the 3?
peace
Hog
Old 09-08-2011, 10:38 AM
  #28
charcold-bowtie's Avatar
A lot of the difference is in the sensor itself, not necessarily its location. I would want to use either a IAT like the one in this thread possibly, or the old msd2320 piece which is discountinued but it appears is still available per google.
Old 09-08-2011, 11:21 AM
  #29
TXsilverado's Avatar
i dont see any power to add with this mod, but possibly with the removal of the maf all together.
Old 12-14-2011, 11:05 PM
  #30
Banned
lsxnation's Avatar
any updated on this mod..?
Quick Reply: IAT Sensor Relocate with Pics
