IAT Resistitor Mod?
Old May 13, 2004 | 06:08 AM
OBXMarine's Avatar
Default IAT Resistitor Mod?
Got this in my email courtesy of ebay this morning:
http://cgi.ebay.com/ebaymotors/ws/eB...%3ASS%3AUS%3A1
Never heard of the IAT mod. I know of the resistor mod for some MAF's. If I could see the resistor values I'm sure I have one laying around. Snake oil? Probably so....
Old May 13, 2004 | 08:20 AM
BigKID's Avatar
You can do it and it will work but.. our IAT sensors are built into the MAF so you will have to cut and splice into the harnes to the MAF to get it in there. Not worth it for the small gains you get, IMHO.
Old May 13, 2004 | 08:55 AM
marc_w's Avatar
I tried it in an older truck - it doesn not work.
I used a resistance that tricked the computer into thinking IAT's were in the 40*F range (or something close to that). All I got was a motor that bogged when floored.
If that guy is only giving you the resistor - that's the biggest rip-off I have seen in a while. You can get a 8-10 pack of them at Radio Shack for like 69-cents.
Old May 13, 2004 | 08:56 AM
marc_w's Avatar
Also, what I did to find out what resistance to use - I removed the IAT sensor, stuck it in the refridgerator for a few minutes, pulled it out, and read the resistance.
Old May 13, 2004 | 09:35 AM
goshawk23's Avatar
Truck addict
there is an article on this at install universtiy's webpage. not sure of the link off hand but they tested the same thing from SLP and found that they got KR from it. they also stated that they have seen it work on some cars and not work on other cars. i guess it's a hit and miss thing.
Old May 13, 2004 | 09:41 AM
F8L Z71's Avatar
Pretty much useless. Especially for long term. The PCM will go around it. after a while.
Old May 14, 2004 | 06:30 PM
ktmrider's Avatar
Yeah, the computer will figure it out sooner or later. Also, it does nothing when the temp is around or below 40 degrees. Summer or warm weather it adds some throttle response but little else.
madmann26
Apr 29, 2020 09:17 AM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
bisqikss
Sep 27, 2015 09:40 PM
GM1697
Sep 9, 2015 10:31 PM
