i think i have a coolant leak, where does everyones coolant lever sit?
If you are using a stud kit,I would try backing the head bolts off about a 1/2 turn each then retorque them in the correct sequence they'll probably reseal.Those high dollar gaskets are supposed to be reusable.
single digit dreamer
Originally Posted by LOW2000
If you used lube on studs, you're not getting an accurate torque reading.
Parish,I'm from the generation that built motors with copper head gaskets and retorqued them after bringing the motor up to temp and letting it cool.Those old copper gasket would seal a leak most of the time.I don't see any reason the Cometics wouldn't do the same.Does Cometic use the same torque specs as a stock head gasket?With the ARP stud kit you might consider increasing the torque to the high side of the suggested torque,then bump them about 5lbs each.
ls1howto.com suggests torqueing them to something like 60 or 70 I think if you use the head studs. I followed the directions on there. If I'm not mistaken, the directions with the studs said torque them to 10 lbs less than original specs. I didn't pay much attn to the directions with the studs, but went by what ls1howto said.
I would give them a good check and maybe a little more pressure.
i retorqed them, they wern't really loose though, the arp instructions said 70ft/lbs when using their lube, i got to about 75ft/lbs before they budged and then it was more of a snaping, not smooth at all like when i just put them on, i think all the molly lube is gone. anyways i got about another 1/8th turn on each. going to take a few days to know if it helped.
