i think i have a coolant leak, where does everyones coolant lever sit?
Old Mar 25, 2004 | 04:51 PM
If you are using a stud kit,I would try backing the head bolts off about a 1/2 turn each then retorque them in the correct sequence they'll probably reseal.Those high dollar gaskets are supposed to be reusable.
Old Mar 25, 2004 | 05:20 PM
parish8's Avatar
single digit dreamer
hmm, i think i will try that, cant hurt
Old Mar 25, 2004 | 06:54 PM
Flyer's Avatar
You might even try a little more torque on them, like 5 more pounds ????
Old Mar 25, 2004 | 07:03 PM
LOW2000's Avatar
If you used lube on studs, you're not getting an accurate torque reading.
Old Mar 25, 2004 | 07:11 PM
parish8's Avatar
what exactly does that mean? i followed the directions that came with the studs and used the lube that came with the studs.
Old Mar 25, 2004 | 07:34 PM
Parish,I'm from the generation that built motors with copper head gaskets and retorqued them after bringing the motor up to temp and letting it cool.Those old copper gasket would seal a leak most of the time.I don't see any reason the Cometics wouldn't do the same.Does Cometic use the same torque specs as a stock head gasket?With the ARP stud kit you might consider increasing the torque to the high side of the suggested torque,then bump them about 5lbs each.
Old Mar 25, 2004 | 07:55 PM
Flyer's Avatar
ls1howto.com suggests torqueing them to something like 60 or 70 I think if you use the head studs. I followed the directions on there. If I'm not mistaken, the directions with the studs said torque them to 10 lbs less than original specs. I didn't pay much attn to the directions with the studs, but went by what ls1howto said.
I would give them a good check and maybe a little more pressure.
Old Mar 25, 2004 | 08:35 PM
parish8's Avatar
i retorqed them, they wern't really loose though, the arp instructions said 70ft/lbs when using their lube, i got to about 75ft/lbs before they budged and then it was more of a snaping, not smooth at all like when i just put them on, i think all the molly lube is gone. anyways i got about another 1/8th turn on each. going to take a few days to know if it helped.
Old Mar 25, 2004 | 09:12 PM
Did you back the nuts off first?That's the way we used to retorque the nuts back them off about 1/2 a turn then tighten them to spec.75lbs. should be plenty tight.
Old Mar 25, 2004 | 11:14 PM
Flyer's Avatar
That would probably keep them from popping like you were saying too.
