i need your two cents
Old Apr 19, 2004 | 03:05 PM
Scream's Avatar
MOOBIES Moderator
Would the bump in compression from 4.8/5.3 heads be worth the swap considering the smaller valves? I know with valves and a good P&P that they are excellent heads--I had been advised to stayt away from them in their stock form though.
Old Apr 19, 2004 | 03:12 PM
2003blue5.7's Avatar
I have 241 casting's now I think I'm going to stay with that casting number but get a set ported and polished. "MTI" have a C! cam that looks pretty good what do you guy think about it? its a 222 / 566 on a 112 center...
also how do you adjust the rocker arms? are they just torqued down?
Old Apr 19, 2004 | 05:23 PM
Flem's Avatar
the rocker arms are a net set design the tolerances in construction are so you just torque them down ,although the aftermarket one come w/ varying thickness shims to set them. 222 is alot of duration for a truck w/o a converter. If you are going to be N/A i would go for the compression bump, maybe have the 241 cut when they are ported. most of the ported 4.8/5.3 heads switch up to the larger 2.00/2.02 valves but have the smaller 61cc chambers. I've got a set of stock 5.3's w/ 14K on them in my garage,
Old Apr 19, 2004 | 07:16 PM
Sport Side's Avatar
best thing to do would be to check in the internal section if your lookin at cams, unless your goin with the common comp 212/218 or 216/220 alot of the guys have experience with
Fellow294
17
Mar 24, 2006 08:55 PM
Mr. Sandog
Nov 9, 2005 11:04 AM
