I need some info on my truck......
Old Sep 17, 2003 | 10:18 PM
Marcel1500's Avatar
Default I need some info on my truck......
I have a 98 Chevrolet Cheyenne Full size pick up. SWB with a 4.3L V-6 and I want to know what kind of tranny I have. I have no clue. It is automatic. That is about all I know about it. Help me out please......Also could you tell me if a 305 could mate to it if I got rid of the V-6.....thanks
Old Sep 17, 2003 | 10:55 PM
Brandon Boomhauer's Avatar
Default Re: I need some info on my truck......
4l60e i would guess....
the 4.3 block is based off the 350. its pretty much a 350 block with the front 2 cylniders hacked off, so the tranny mounting points are the same.
so i would guess that a 305 would mount up, yet why you would want a 305.......
you will be able to find out some more info on fullsizechevy, as that site deals with older trucks (pre 99, ls1 based engines)
Old Sep 17, 2003 | 11:10 PM
Yelo's Avatar
4L60E.....
ANY smallblock (and MOST bigblocks) will bolt to that trans pattern....
if you are gonna swap engines skip the 305 and go for a least a 350....if you can find one get a 400 truck block, drill the steam holes in a set of Vortec heads and bolt those on
Old Sep 18, 2003 | 03:38 AM
Flyer's Avatar
ANY rear wheel drive, with the exception of the heavy trucks, that GM makes with an auto has some sort of 4L60 in it. The bell housing may be a little different, but it's the same tranny. Yelo is right, that 4.3 is just like the 350 minus 2 cylinders. That means, if you wanted to build a hell of a sleeper, you can get pistons, cams, heads, rods, and some other stuff for it and have a pretty decent motor.
Old Sep 19, 2003 | 08:06 PM
Marcel1500's Avatar
I dunno why I wrote 305 I meant 350! If I wanted to put an ls1 in my truck could I use the computer on my truck now or do I need one specially for the ls1. Can I use the computer from a vortec v-8 out of another truck? Is there any problems with running the ls1 with a 5 speed tranny as aposed to a 6 speed? Thanks also what would be needed as far as fuel goes. Do I need to up grade? What can I spare from the fuel set up that I have right now? thanks again!!!!!
RustyD
May 23, 2016 07:04 PM
slimchevy2
Oct 4, 2015 08:02 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
Wolftrk99
Oct 2, 2015 08:17 AM
Silver8ado
Sep 30, 2015 11:42 AM
