I need a little advice guys!!
Old Jan 8, 2016 | 09:26 PM
rayfrausto's Avatar
Default I need a little advice guys!!
So I have been doing a whole lot of reserch I've Google serched this forum in paticular cause I have a 5.3. So here it goes I'm building me a g body cutlass with a 5.3lm7/4l80e I have. The plan is to slap in the motor get my car back on the road and then work out kinks and throw on a turbo kit on it after about 6mo-year. That being said I would like a fun na car in the mean time. So this was a budget setup I came up with to get car running and on raod. I'm hoping this will satisfy me in the mean time! If I were to have a goal I would say 340-350rwhp but as long as she feels strong it will make me happy.
5.3/stock 706 heads shaved to Bump compression.
Ls6 intake,rail,injectors
Stock ported tb
Tfs 220/224 .575 lift cam (have not purchased yet)
278 circle d hp 3200stall(have not purchased yet)
8.8 ford 3.73 gears
So this will b my budget combo for my 5.3 in my cutlass. Will this be a a strong ride? Once ready for turbo 799heads will go on with custom grind cam. So I'm just looking for a good cam to run na meantime. I was even considering sending heads to tsp for stage 2.5 job but then I said to myself this is suppose to be budget friendly till turbo is ready. But I still may pull the trigger on them lol. Well guys is this a good moderate cam and stall? Thank in advance for opinion
Old Jan 8, 2016 | 09:33 PM
Wolftrk99's Avatar
Make sure those 706s arent castechs before you get too far into those heads....
Old Jan 8, 2016 | 11:49 PM
rayfrausto's Avatar
Yea I read about that somewhere. The heads were just a thought but I think I will just mill heads a little sence I'm going to get 799 heads when I put turbo on. Just wondering if this "budget build" would work good together to get her running again. That cam in a 5.3 is not pushing the circle d converter to its limits? Would be nice for a lighter g body car? I think I might just order it
Old Jan 8, 2016 | 11:53 PM
Wolftrk99's Avatar
Shouldnt be, that stall shoukd be perfect for it running similar cam in my 99 at moment and need a 3000-3200 stall... If youre gonna run 799s why not save hassle of the 706 and go ahead and get them on while you have the engine apart...
Old Jan 9, 2016 | 02:57 AM
rayfrausto's Avatar
I have thought about that, but I thought it be better to run shaved 706 to try and bump to 10:1? Then to throw 799 heads on it now and drop compression. I was thinking 799 heads with turbo would be perfect to keep my compression good? I even have some flat tops from a 4.8 I was gonna throw in real quick but I think I decided not to pull pistons sence ima boost it anyways
tim wellington
Nov 25, 2015 06:00 PM
echoman
Nov 21, 2015 09:33 AM
40series
Nov 19, 2015 07:17 PM
VETTEKILR53
Nov 18, 2015 03:09 PM
Tuskyz28
Nov 7, 2015 09:20 AM
