I need help
Old Oct 29, 2006 | 08:19 PM
Daryl4.8's Avatar
Default I need help
What is the differents from a 112 LSA AND 114 I dont know
Old Oct 29, 2006 | 08:22 PM
nightrunner's Avatar
Mr. Obvious
from what i hear the 112 has a more of a lope in the idle and is harder to tune but the 114 has a smoother idle and is easier to tune
Old Oct 29, 2006 | 08:23 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
The Cam Thread
Start here.......There is some good info.
It's a bit more complicated than that. Overlap and other things I barely understand
Old Oct 29, 2006 | 08:36 PM
one03sierra's Avatar
Formerly one92rs
the 112 is going to be a great naturally aspirated cam for the novice modder. it is going to be a little tougher to tune and might have some stall characteristics at times. the 114 is going to be an easy cam to tune and is going to have a much better idle characteristics. now go and read the cam thread and this will all make sense.
Old Oct 29, 2006 | 10:04 PM
Varying Lobe Separation Angle.....................................
...............Tighten............................ ..............Widen
Moves Torque to Lower RPM..............Raise Torque to Higher RPM
Increases Maximum Torque................Reduces Maximum Torque
Narrow Powerband...........................Broadens Power Band
Builds Higher Cylinder Pressure............Reduce Maximum Cylinder Pressure
Increase Chance of Engine Knock........Decrease Chance of Engine Knock
Increase Cranking Compression...........Decrease Cranking Compression
Increase Efective Compression...........Decrease Efective Compression
Idle Vacuum is Reduced....................Idle Vacuum is Increased
Idle Quality Suffers..........................Idle Quality Improves
Open Valve-Overlap Increases...........Open Valve-Overlap Decreases
Closed Valve-Overlap Increases.........Closed Valve-Overlap Decreases
Natural EGR Efect Increases..............Natural EGR Efect is Reduced
Decreases Piston-to-Valve Clerance....Increases Piston-to-Valve Clerance
