I know, I know, another hooker aerochamber question??
Old Nov 6, 2005 | 07:54 PM
ap2002's Avatar
Default I know, I know, another hooker aerochamber question??
I need to know if the hooker aerochamber is actually a straight thru design??? can somebody that has physically looked at one say that you CAN see from one side to the other??? hopefully I'll be ordering it tomorrow but I want to make sure it is a straight thru desgin....
thanks...
Old Nov 6, 2005 | 08:30 PM
99Silver6.0's Avatar
thanks...
Its close to it. Ive checked one out at work. If you hold it at the perfect angle you can see out the other hole.
Old Nov 6, 2005 | 08:35 PM
lotzafun's Avatar
Do they make a muffler that has one inlet and two outlet openings?
Old Nov 6, 2005 | 08:58 PM
v8
17,16,15,14,13,12,11 Drvr
ap2002 why worry about a muffler when you have the cut out lol, your truck sounds good now, you just need to work it better then you have it we were kinda confused about the set up lol
Old Nov 6, 2005 | 09:35 PM
StrokerAce03's Avatar
Why you changing mufflers; something wrong with the Borla or just want a change in sound?
Old Nov 6, 2005 | 10:01 PM
Zick's Avatar
This is their straight through design.
Old Nov 6, 2005 | 10:54 PM
w41quad4's Avatar
the Aerochamber is a straight thru muffler. If you take for example a 3"I/O on centers you can see straight through it, no baffles, yet its still a chambered muffler. The offset inlet & outlets you can't see straight through due to the internal case design, but they are a straight thru setup, especially if you go with a center in/center out.
BTW-they do make a single in/dual out
Old Nov 6, 2005 | 11:08 PM
Flyer's Avatar
They will flow as well as or better than any other muffler will.
On the offset, you can see through it, but obviously, since it's looking through it an an angle, it's not a straight shot. The center in/out would be a straight shot, but it's still baffled.
I got a sound clip in my sig for the Aero Chamber.
Old Nov 6, 2005 | 11:57 PM
Formulized94's Avatar
well, that sound clip just made my mind of what muffler to use. Aerochamber it is, I had them on my lt1 car with lt's and 3" duals, sounded wicked and different, so thats what my truck gets. Only if i could get it running right
Old Nov 7, 2005 | 01:16 AM
ap2002's Avatar
ok that clarify's alot, I will be getting the 3"centerin/3"centerout...
I actually love the way the Borla sounds but I guess I just want a change in sound, and eversince I heard Flyer's clip months ago I've just been wanting to change... so Im going to go ahead and do it...
yeah kevin, I have a cutout but only like how it sounds @ idle and @ WOT... other than that the raspiness kills it... I'll have the cutout for the track about the exhaust setup its a long story...lol.. lance asked about it too!!
lotzafun & w41quad4 - yes, they have a single in/dual out but it is a 2.5"inlet/outlets in a small case.... that's why Im jus going with the 3"in/3"out
