I just order 243s stage ll for the lq9!!!!
Old Aug 14, 2009 | 10:04 PM
Michael Halo's Avatar
Default I just order 243s stage ll for the lq9!!!!
I wonder what my numbers will be at the wheels
With a full bolted lq9 228 230 cam and the TEA stage ll heads????
Old Aug 14, 2009 | 10:34 PM
OrlandoFL4.8's Avatar
getting bored with my lq9 setup, by going to the 243 heads is that going to up your CR compared to the 317 heads? How much more power do you think it will be worth on your setup? Thanks
Old Aug 15, 2009 | 08:47 AM
Well my cr should be right at 11.1 on a lq9 every 4cc is worth 0.5 point 8cc is worth
1 full point over the stock 10.1 317 72cc heads so the 243s are 64cc which is 8cc less
Then the 317s which makes it 11.1 and as for my step I hopeing for 420+ rwhp
If you was to do 243s stage ll to your setup on you sig you'll most likey be looking
At 50-65 rwhp easy
Old Aug 19, 2009 | 01:10 PM
03 BLACKOUTSSS's Avatar
will you run into any P2V clearance issues with that cam and heads combo?
Old Aug 24, 2009 | 01:58 PM
Most likey no but it's always good to check
carid
Oct 28, 2015 08:24 AM
chopperloco
Sep 28, 2015 08:40 AM
bisqikss
Sep 8, 2015 03:35 AM
screaminian47
Sep 7, 2015 08:20 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
