I hate putting lifters in :-( (pics)
Old Aug 31, 2005 | 07:26 PM
chevyerett's Avatar
Oh yeah anybody got any advice on the easiest way to put the heads on since they are such PITA. Havent ever put a set of these heads on a motor. I should have gotten the ARP stuff but I have to have it back together by tomorrow night so I can drive back to Texas.
Yeah, you get a really long piece of pipe, and pull on it for all your worth.
I started out just using my socket and ratchet, and nearly died. Put the cheater pipe on there and made things a lot easeir.
Old Aug 31, 2005 | 07:28 PM
chevyerett's Avatar
Originally Posted by BigBlockChev572
The clearance between the pump housing and crank "snout". If not gapped properly it can cause uneven wear of the pump. You're supposed to install two of the bolts diagonal from each other loosely and put two feeler gauges at .002 and spin them around to make sure the pump is centered, then tighten up the bolts and install the other two. I did it, it was a PITA, had to redo it like 3 times, I still don't know if I have it all aligned 100%. It's hard to do it by yourself like I did.
Philip S.
Oops...I just bolted my on....
Old Sep 1, 2005 | 06:25 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Yup I just bolted mine on too and all that **** is NOT coming back off. Ill deal with the problem later on down the road. I got the heads and intake back on last night. Tonight I should have it running just need to bolt the exhaust up, cooling system and all the bracket bs on the front of the engine.
Old Sep 1, 2005 | 09:08 AM
BigBlockChev572's Avatar
Hell yeah, I know what ya mean. Keep us updated. Congrats on getting everything together!
Philip S.
Old Sep 1, 2005 | 09:51 AM
white1's Avatar
1SlowZ71, how much of a PITA is dropping the oil pan on a 4x4? I have something that needs to be fished out of mine
Old Sep 1, 2005 | 10:50 AM
1slow01Z71's Avatar
NOt bad at all the back two skinny bolts right by the bellhousing run them almost all the way out but not quite take the two bottom bolts out of the bellhousing and then take all the rest of the little ones out there are two on top of the front differential that are a PITA but after you get those out the oil pan will drop down and rest on the cross member down there and oyu have to take the skid plate off too to get to the bolts. Takes about 30 min to drop it.
Old Sep 1, 2005 | 10:52 AM
1slow01Z71's Avatar
Oh I see you need to take it all the wya off in that case just take the two long skinny bolts all the way out and you will have to lift the deep part of the oil pan up and over the crossmember but it shoulfnt be too hard I just dropped mine down to take the oil pump off I would suggest a pin magnet between the block and the oil pan to fish around for the bolt or nut that you dropped instead of having to pull it all the way.
Old Sep 1, 2005 | 12:28 PM
white1's Avatar
Yea, I was just planning on dropping it enough to fish the bolt out. Thanks
Old Sep 1, 2005 | 12:39 PM
1slow01Z71's Avatar
No problem man wont take long but you will definately need a wiggle joint. Make sure you are extremely easy putting the two thin long bolts at the back of the oil pan back in their torque spec is only like 9 ft-lbs so you can break one VERY easily.
Old Sep 1, 2005 | 12:50 PM
chevyerett's Avatar
Yeah, that one didn't like the 18ft/lbs. I put on it .
