I finally bought a cam for the 4.8!!!!
Going w/ that size of cam you might want to look at something a lil bigger than the tt3000. Its gonna need a good amount of convertor to make up for your low-end power loss. Not trying to rain on your parade here, but why go that big on a motor that is already lacking down low?
Resident Retard
Well IMO if I was going all out and wanted maximum benefit your probably correct on needing a higher stall verter... However the TT3000 is the max I am going to go, So I if have a little flat spot from a stop, so be it... Honestly I plan on taking the truck to the track after the cam install and running it several times to see exactly what my 60ft does without a verter. Then once I install the verter I will be going back to the track again to see the affects on my 60ft....
currently I am runing a consistant 2.3 60ft...
