Huge "BANG" from the rearend of truck
Old May 28, 2004 | 03:03 PM
blownZ71's Avatar
I had the same thing happen to me, but I actually blew an inch diameter hole right out of the bottom of the differential housing If it is still drivable then it is quite possibly the spider gears, or even the actual ring. I have broken every component in there including the eaton spider gears on mine at least once. If it is the spider gears just remove the unit like Big Tex said if you are trading it in.
Old May 28, 2004 | 03:46 PM
Originally Posted by ILLNALI
my whole backend felt like it got hit and the truck went sideways and I almost lost it. I was making a 80mph turn when it happened.
This isn't one of the times you wound up in a ditch is it?
Old May 28, 2004 | 04:20 PM
SierraSport's Avatar
Im guessing you broke a tooth off your Ring , I have done that ...
Old May 28, 2004 | 06:20 PM
04BlackSilverado's Avatar
Can the tooth be welded for a band-aid fix?
Old May 28, 2004 | 07:10 PM
if you know the best welder around......yes, realisticly no, who needs all the teeth anyway, thats just more weight, that tooth is worth .0000001 of a sec
Old May 28, 2004 | 07:44 PM
Is the tooth missing leaving enough of a gap that it will miss the space and spin like in neutral?
Old May 28, 2004 | 08:56 PM
CHAGO's Avatar
almost but no!
Old May 28, 2004 | 10:17 PM
Probably , plus that peice is now flooting around in that rearend making even more problems ...
Old May 30, 2004 | 06:59 PM
HAZE's Avatar
sounds like you granaded the gov loc, from what i've heard this is common. gm's safety feature of having the locker violently unlock over 25 mph is ridiculous and costs alot of people alot of money. when i lifted and changed gears my shop suggested i get rid of it, i was sceptical but i trust them, and i'm glad i did. i went with the high end [stronger, heavier spring] limited slip, burns both tires on pavement. they told me if the stocker granades it can take the spiders and in some cases the ring and pinion with it. if it still drives you may be ok but i'd get it looked at right away, if there are stray parts floating in there it's only a matter of time before they get stuck in the gears and blow the whole thing. if it's only the locker your looking at $400 + for a new l.s or locker + labor.
Old Jun 2, 2004 | 11:03 AM
BlackDog's Avatar
Hey Guys, thanks for the replys. Sorry I haven't responded back. A friend of mine died Friday and I have been away. When I got back, My buddy's wife had a baby. So I have been pretty busy. I will take that cover off tonight after work and post what I see. Thanks again fellas.
