HRP 7/3
Old Jul 3, 2002 | 10:15 AM
1 BAD GM's Avatar
Default HRP 7/3
Well guys I hope that the weather holds out. I really want to make it out to HRP this evening. The last time I went I ran a best of a 15.21@~91mph. Since then I have added a torque converter and TransGo, so we will see what happens. The only problem is that I have a feeling that I am going to have major traction issues. I just filled my truck up with gas on Monday night, so it will probably weigh more than the 4980lbs. that it weighed last time. Unless I can waste a lot of gas before tonight. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
I'll keep you guys updated!
Old Jul 3, 2002 | 11:30 AM
MAD_RACING's Avatar
Default Re: HRP 7/3
I might swing that way it's about 5 minutes from the house and I'm interested what my new suspension will do..... <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Jul 3, 2002 | 09:15 PM
Vortech5300's Avatar
Default Re: HRP 7/3
Hey GUys, post how your trucks run. I will probably run this sunday night to test the gains of the HPP3 and servo. Least the humidity is down some tonight, you should run decent. Take pics to. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jul 4, 2002 | 11:08 AM
Default Re: HRP 7/3
WEll, did you guys go to HRP? Results?
Old Jul 4, 2002 | 07:15 PM
1 BAD GM's Avatar
Default Re: HRP 7/3
Well I went out there. But I was having major traction issues with the new torque converter. I had wheel hop like crazy. I tried stalling it up to 2000.....wheel hop! 1500....wheel hop! 1000....wheel hop! flashing off idle....wheel hop! Only way to hook was to roll into the throttle.
Then I started picking up a lot knock in third gear, probably because of the heat and humidity. So, I took the HPP3 programming off and ran a 15.165 @ 89.14 w/ a 2.121 60'.
With traction I think it would have ran and easy 14.9 maybe better.
In better weather probably a 14.5 or so. I can't wait for the winter again.
Old Jul 4, 2002 | 07:17 PM
Default Re: HRP 7/3
Pretty good 60' considering you were leaving easy. What are your mods again? ext or reg cab? 5.3?
Old Jul 4, 2002 | 07:19 PM
Default Re: HRP 7/3
Uh nevermind, I see your mods in the 1st post. DOH!
Old Jul 4, 2002 | 07:22 PM
Default Re: HRP 7/3
BTW you may try slapping on some leaf spring clamps to put a little more pre-load on the springs. I guess Cal Tracs and ET streets are next for you eh? <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
truckahaulic
May 17, 2006 05:50 PM
Onyx 02
Apr 6, 2006 12:26 AM
1slow01Z71
Mar 26, 2006 09:54 PM
CHEVY6000VHO
Dec 30, 2005 01:00 AM
sleek silverado
Aug 16, 2005 10:56 AM
