HPPIII shift settings
Old Apr 24, 2002 | 11:37 AM
primetime's Avatar
Default HPPIII shift settings
I'm sure this topic has been discussed again and again. I tried a search but I couldn't find what I was looking for? I have a 99 Silverado 5.3 with 3.73 gears. What is the best shift points from experience? I'm currently shifting at +3,+6. That's about 5600rmp+/-. I was told that stock shifts at 5200rpm+/-. My seat of the pants meter didn't feel like the truck was pulling at the higher rpms. Maybe I was mistaken. Any help and advice would be great. Thanks guys. <img border="0" alt="[Truck]" title="" src="graemlins/gr_truck.gif" />
Old Apr 24, 2002 | 01:04 PM
Scream's Avatar
MOOBIES Moderator
Default Re: HPPIII shift settings
I just got my HPPIII and went to the track last night. I have a 4.8L SCSB with 3.42's, and I set the rev limiter @ 6200, ***** at +5 and +12. I got my best times with this setup, BUT...
I have heard from several people that there may be an issue with pushrod life at this rpm. I ran my best mph with those settings (70.08 in the 1/8)and spun with a high 2.3 (like 2.37 or 2.38) 60'.
I didn't see a great increase in the 1/8 by bumping up the shift points, so I think that I'm going to set mine back to 6000, +4 +11.
L8R,
Scream <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old Apr 24, 2002 | 01:40 PM
I don't push mine past 6100 rpm's when using the HPP. With 3.73's, the max I can go is +4 from 1-2 (6112 rpms), 2-3 +12 (6012). I have it set for +3 (5986) 1-2 and do have it at +12 for 2-3, putting 1-2 at +4 didn't produce better times so I figured why push the engine.
Jim
Old Apr 24, 2002 | 02:07 PM
primetime's Avatar
Can snyone confirm that the stock shift points for the 99 truck are around 5200rpm? Y2K...does your truck still pull at 6grand on the tach?
Old Apr 24, 2002 | 03:32 PM
I'm shifting @about 6k with 4.10/1 but the help
is [I think] because I'm cathing 2nd & 3rd 500 rpm
higher so it's not as flat after the shift.
Old Apr 24, 2002 | 07:58 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Can snyone confirm that the stock shift points for the 99 truck are around 5200rpm? Y2K...does your truck still pull at 6grand on the tach?
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yep, my tach goes to 6K when shifting. From what I've read, 99 trucks shifted from all gears at 5200 rpm's. 00+ trucks shift from 1-2 at 5600, then 5200 for all the rest, they put a different cam in the 00+ trucks. Yours being a 99, it might not like being reved to 6K because of the cam. If stock is 5200, then 5600 may be your max!?
Jim
Oobray
Jun 13, 2022 03:38 AM
pittman
Jan 19, 2016 07:06 AM
fastjweb
Aug 15, 2015 10:47 AM
Sexyrado327
Aug 2, 2015 04:08 PM
lxcoupe
Jul 14, 2015 10:14 PM
