how should I delete my cats
Old Aug 5, 2019 | 07:35 AM
deer killer's Avatar
Registered User
Default how should I delete my cats
my 02 Silverado’s cats r going bad and I planned on getting rid of them anyways but how should I delete them? Weld a pipe where they were at? Could I clamp a pipe in there? I’m not gonna gut them bc most people say they don’t sound as good or perform as good as replacing them with straight pipe. Also what size pipe would I need? Thanks
Old Aug 5, 2019 | 09:08 AM
arthursc2's Avatar
Long tubes and y pipe
Old Aug 5, 2019 | 11:05 AM
RedXray's Avatar
100% Redneck
Weld in a pipe to replace the cats. If you want or need (state inspection) to have visible cats you can gut them and weld in a pipe to eliminate the gutted echo/ringing sound. The rear o2 sensors are going to throw a code that will not pass state inspection if needed. This code will not effect performance. You can have that SES light turned off in the tune, but can be expensive, you may as well have a full tune performed. Before the FEDS cracked down you could buy o2 eliminators really cheap to turn off the codes to pass state inspection. I bought this one from Baker Electronics for $40
Old Aug 5, 2019 | 05:59 PM
01FormulaTA's Avatar
Off Road Y-Pipe
https://www.jegs.com/i/JEGS/555/31004/10002/-1
https://www.ebay.com/itm/99-06-GM-1500-Stainless-Exhaust-Ypipe-Chevy-GMC-Y-pipe-2wd-4wd-Sierra-Silverado/152786270906
Old Aug 5, 2019 | 07:07 PM
Jake Wade's Avatar
Interesting. I wonder if the Jegs system will fit '06? It says '99-'02
Old Aug 8, 2019 | 04:42 PM
00pooterSS's Avatar
If you're gonna leave the stock manifolds and Y pipe in place gutting them will work fine. Other wise get long tubes and an off road y pipe and a good catback exhaust if you want to see a worthwhile hp increase.
Then get it tuned and have the tuner disable the rear oxygen sensors so you don't get a check engine light. The money you would spend on some 02 simulator device could be put toward or pay for the tune. Unless it's super cheap like the one red x ray posted.
BLKSSLTT
Sep 6, 2018 08:31 AM
Matt331
Mar 22, 2015 02:02 AM
jm's customs
Apr 5, 2006 12:55 PM
thunder550
Jul 8, 2005 02:26 AM
Gustin
Feb 29, 2004 06:49 PM
