How to Program Remote???
- Enter the vehicle and close all doors, make sure the courtesy light is not on.
- Perform the following within a 10 second time span
- Turn the ignition to the "ON" position
- Using the dash mounted courtesy light switch turn the lights ON-OFF, ON-OFF, ON-OFF pausing 1 second between each rotation.
- Turn ignition off
- The locks will now cycle 3 times to indicate vehicle is in programming mode
- Press the "Lock" button on each remote you want vehicle to recognize, locks will cycle once for each successful recognition
- When done turn ignition on and then off to exit programming mode
I bought a remote FOB from Ebay with no instructions and found them here...
http://nvo.com/chipkeys/chevroletkeylessremotes/
Hope this helps.
Hope this helps.
zblee
Sep 17, 2015 07:58 AM
