How My Little 5.3 Performs
Old Jun 17, 2005 | 06:17 AM
  #81
sd155racer's Avatar
got the pictures....warning they suck but you can still make them out.
HITTING 120MPH......rpm's=5,000
RPM's at 5,500 with speed needle in same exact spot(maxed)
if my ghetto math is right im around 130-132 on a setup that is suposedly IMPOSSIBLE factory from the tank to the injectors, no cam, no nitrous, ecsb pig at full weight+full tank and system. and had no problems getting there. it had more left in it...
on a side note, 01Thunder is lucky that his air dam didnt fly out of the bed of my truck on my way to drop it off
Show me something in digital numbers - I wanna see what the REAL speed is - not what a POS gauge is telling you. The gauge is wrong - watch the vid again and you can see that GM gauges always read faster than actual speed.
But that's pretty bawlsy taking cell phone pics at 120
Old Jun 17, 2005 | 06:22 AM
  #82
sd155racer's Avatar
Originally Posted by 2003Silvyrado
You guys are insane. I get scared going 110. Telephone poles fly by pretty quick at that speed. Man, if you pop a tire going 120 or so.... oh my, and what good are awsome brakes when driving on a wet road? Your tires are floating at that speed.
Dude I know all about tires floating and speed - thanks for your concern
Besides - I've got some serious rubber grip
Old Jun 17, 2005 | 09:01 AM
  #83
rgvsierra's Avatar
when i get a chance, i will show you my hptuners screen and how its gonna go past 122. i probably wont get it on vid, but i will post screen pics of it.
Old Jun 17, 2005 | 09:26 AM
  #84
Mangled03gmc's Avatar
Baltimore Whore
I guess i have a total freak cause i have hit the hppjunk rev limiter a few times.That is with a 4.8. It takes a while to get there but it can an has been done. Just need a long long stretch of road
Old Jun 17, 2005 | 09:30 AM
  #85
sd155racer's Avatar
There are 3 different shut down speeds for the HPP3.
Old Jun 17, 2005 | 10:42 AM
  #86
Zick's Avatar
Originally Posted by sd155racer
Geez - the 405 was on the bottle, I'll dig up the dyno sheet someplace -
How big of a shot?
Old Jun 17, 2005 | 11:08 AM
  #87
Baltimore Whore
Yes but I went for the highest one 128
Old Jun 17, 2005 | 11:34 AM
  #88
lm7's Avatar
lm7
i alwyas hit the 128 limiter on my 275/45/20 the stock tires get way to crazy on the top end.....
Old Jun 17, 2005 | 12:20 PM
  #89
TXsilverado's Avatar
i just watched it. at 120 your guages sit right at 5,000 rpm and your laptop says it too. it goes back and forth proving that they aretn THAT far off. if i had the equipment to prove it digitally i would but im sure you would just make more excuses of how your still right. accept it, our trucks can get past 122 without changing injectors and pumps. im sure yours will too, you probably have just have a little tuning issue up top, or maybe its the elevation your at. my basically stock truck pulled to 120 a whole lot harder than your 405hp beast.
Old Jun 17, 2005 | 01:00 PM
  #90
Avalanche2002's Avatar
If you want to know how fast you are going, use a GPS unit. It'll tell you exactly how fast you are going.
I pegged the HPP3 rev limiter at 128 mph on my Av several times before I installed the Radix. It would be a whole lot easier to get there now but I haven't pushed it over about 105 yet.
